center console attachment question, 67 fhc
autoalain
#1 center console attachment question, 67 fhc
Post by autoalain » Wed Apr 03, 2024 11:42 am
Folk,s I have just recovered the center console and the TOP part where shifter boot is, does this
part (top)just sit on top of whole unit or is it glued on , mine is very thin wood (covered), and
not sure of the attachment process on this basket case 1976 fhc
andrewh
#2 Re: center console attachment question, 67 fhc
Post by andrewh » Wed Apr 03, 2024 6:02 pm
Perhaps you can post a photo, as I am not sure what you are referring to. TO my knowledge there is not wood in the centre console area ?
1962 3.8 Series One FHC
#3 Re: center console attachment question, 67 fhc
Post by mgcjag » Wed Apr 03, 2024 6:42 pm
Typically bent metal tabs hold it on..have a look here..very easy to find if you use the search function viewtopic.php?f=4&t=10030&p=79274&hilit ... ole#p79274
Allrand
#4 Re: center console attachment question, 67 fhc
Post by Allrand » Thu Apr 04, 2024 6:57 am
IIRC it goes in below the metal top, held in by metal tabs as indicated by Steve. There is a thin leather covered wooden panel over the steel top. The attached pic is a 3.8, I think the 4.2 is slightly different. Missing on mine is the upholstered piping around the edge of the shift cover, just not enough space due to the thickness of the new leather.
Randall Botha
