Clutch Release / Thrust Bearing Conversion
Retroman
#1 Clutch Release / Thrust Bearing Conversion
Post by Retroman » Sun Jan 31, 2021 5:38 pm
Hello E Type Fettlers,
Gathering together parts for my auto to manual conversion and wondered has anyone converted from the fork activated thrust bearing to a direct hydraulic type similar to the type supplied in the ‘Driven Man’ gearbox kit.
I am fitting a Jag MOD into the car with a standard 4.2 bellhousing etc so now would be the time to try this mod of it is practicable.
There must be something out there in the car parts universe that would be a cheap solution.
Anyone out there done this with any degree of success?
Cannot find anything on the forum
Thanks,
Nigel.
1969 E Type Series 2 2+2 Auto with Power Steering UK Registered
#2 Re: Clutch Release / Thrust Bearing Conversion
Post by mgcjag » Sun Jan 31, 2021 7:08 pm
Nigel....lots of discussions on this on Jag Lovers forum if you search. ...Steve
Retroman
#3 Re: Clutch Release / Thrust Bearing Conversion
Post by Retroman » Sun Jan 31, 2021 9:40 pm
Thanks for that Steve
johnetype
#4 Re: Clutch Release / Thrust Bearing Conversion
Post by johnetype » Mon Feb 01, 2021 12:38 am
Given the unreliability of the "direct hydraulic type" as you call it and the need to remove the engine and gearbox to service it why would you want to use one?
The external slave cylinder arrangement with clutch fork and bearing may not perfectly reliable but at least it's cheap and easy to repair.
1969 Series 2 FHC
#5 Re: Clutch Release / Thrust Bearing Conversion
Post by christopher storey » Mon Feb 01, 2021 8:04 am
:yeahthat:
#6 Re: Clutch Release / Thrust Bearing Conversion
Post by PeterCrespin » Tue Feb 02, 2021 1:46 am
.. has anyone converted from the fork activated thrust bearing to a direct hydraulic type similar to the type supplied in the ‘Driven Man’ gearbox kit.
I am fitting..... a standard 4.2 bellhousing etc so now would be the time to try this mod of it is practicable.
A good friend did the opposite. He opted to keep his BW bell and use an hydraulic release when ditching his XJC auto for a manual. Not many miles later he spent time and money rectifying clutch slip by switching to standard Jag bell and fork. No trouble since. You have been warned...
madjack4
#7 Re: Clutch Release / Thrust Bearing Conversion
Post by madjack4 » Tue Feb 02, 2021 10:59 am
As said above im in motor trade i have changed loads of concentric slave cylinders they are very unreliable from new stay clear stick to outside slave cylinder
Rob 1972 s3 roadster
Aston Martin DB9 Volante
Retroman
#8 Re: Clutch Release / Thrust Bearing Conversion
Post by Retroman » Wed Feb 03, 2021 10:22 pm
Many thanks for the advice Chaps.
This is clearly not one of my better ideas.
Sacking it and going with the original fork etc.
Thanks again,
Nigel.
