#1 Lucas relays
Posted: Fri Feb 05, 2021 5:21 pm
by Fspp369
Not sure if this is any use to anyone but here you go..
Handy little list of 6RA relays etc from the TVR club.just click on the first google suggestion.
It’s from the club across the pond.
http://tvrna.tvrccna.org/lucas/lucas-relays-6ra.htm
If I’m behind the times accept my apologies.
Peter
#2 Re: Lucas relays
Posted: Fri Feb 05, 2021 5:34 pm
by cactusman
Excellent.....many thanks for posting....
#3 Re: Lucas relays
Posted: Fri Feb 05, 2021 10:28 pm
I have this as a PDF.
David do you want it for the KB?
#4 Re: Lucas relays
Posted: Sat Feb 06, 2021 1:37 am
by rossco_j
I think a .pdf file in the knowledge base is an excellent idea.
#5 Re: Lucas relays
Posted: Sat Feb 06, 2021 8:40 am
by MarekH
Aside from the starter motor relay, you can usually make what you need out of a changeover relay. For most of the variants used on the car, simply externally connect the c2 terminal to one of the w terminals and leave the unwanted terminal unconnected.
#6 Re: Lucas relays
Posted: Sat Feb 06, 2021 8:48 am
by Fspp369
If you click on the original link just then click print and the pdf is usually created...save or print. ..!
Peter
#7 Re: Lucas relays
Posted: Sat Feb 06, 2021 10:12 am
by PeterCrespin
Steady on lads. This has the potential to be a ‘super-spreader’ file... Using anything from the TVR crowd could turn our cars into fibreglass with half-inch panel gaps, and make the dash switches and window winders snap off after first use!
#8 Re: Lucas relays
Posted: Sat Feb 06, 2021 12:32 pm
by Fspp369
Ahh Yes but once you've been impregnated, once now and if necessary, again later (yet to be decided) you won't get any body rot
#9 Re: Lucas relays
Posted: Sat Feb 06, 2021 2:14 pm
Already in the KB, been there since August 2018 but thanks for the thought.
