Whether you have hardwood floors or carpets in your home, you need a good vacuum cleaner to keep your house clean and tidy. What are the best vacuum cleaners? We’ll help you get a clear answer with the below review.
1. Miele Electro+ Canister Vacuum Marine Blue (Compact C2)
In our opinion, Miele is the best vacuum brand on the market for carpeted floors as it’s equipped with optimum carpet care. But what exactly does that mean? Well, the electro brush is designed for deep cleaning of heavy-duty carpeting. So does it work on hardwood floors? The good news is that users don’t have to worry, as it works gently on sensitive hard floors as well, thanks to the soft parquet brush.
Manufactured in Germany, Miele’s Electro+ Canister Vacuum (or Compact C2) is pretty well-known for its suction power and low noise output. We’re big fans of its air filtration capabilities too, as this vacuum has two filters: a pre-motor filter and a post-motor filter. Each of them has its own function: while the pre-motor filter removes small particles, the post-motor filter is a HEPA AirClean filter (HEPA stands for High-Efficiency Particulate Air, which refers to filters that are capable of filtering 99.97% of particles as small as 0.3 microns). Miele’s Compact C2 is no doubt a not-to-be-missed vacuum cleaner for your home!
2. Ryobi 18V Cordless Hand Vac Floor Care Kit (R18HVF-0)
Reasonably priced, this 18V cordless vacuum cleaner from Ryobi is sufficiently powerful. With up to 1300 l/min of airflow, it effectively cleans the floors of your home, cars, or even larger spaces. As a stick vacuum, it’s a perfect compact tool for cleaning the most hard-to-reach areas of your place, such as your stairs, bookshelves, window edges, or in between sofa cushions.
Also, this hand vacuum is equipped with a dust bowl to quickly dispose of all of the mess. However, tall users (those over 6.5 ft) would find this lightweight vacuum a bit inconvenient, as it doesn’t allow them to stand up straight while working on the floors of their house. Other than that, the Ryobi 18V cordless hand vacuum cleaner is a wallet-friendly device that does its job pretty well.
Find More Info: Best Vacuum Cleaners
3. BLACK + DECKER dust buster Handheld Vacuum, Cordless, 16V (CHV1410L)
One of the most annoying problems with handheld vacuum cleaners is the battery life. In almost all cases, the battery does not last very long on these devices. Plus, once it’s completely depleted, it takes a few hours or even one full day to recharge. BLACK + DECKER’s handheld vacuum cleaner, however, is an exception. Thanks to a fade-free Lithium-Ion battery, its battery longevity is unparalleled.
Moreover, the high-performing extending pivoting nozzle and brush attachment of this handheld vacuum allow you to perform different cleaning tasks around the house with little effort. Hidden corners like in-between car seats or awkward spots such as the bottom edges of kitchen tables won’t challenge you anymore. Overall, the BLACK + DECKER dust buster Cordless Handheld Vacuum represents strong suction in a handheld device with impressive battery life.
The bottom line
While durability is the first criteria that many people look for in a vacuum cleaner, a compact design is essential for others. That said, the best vacuum cleaners are the ones that fit your needs best. We hope Best Vacuum Cleaners Reviews was informative. Click share if you like this post, and feel free to leave us comments below.
