Bleeding front brakes with wheels on
rossbraithwaite
Topic author - Posts: 173
#1 Bleeding front brakes with wheels on
As the title suggests; how easy is it to bleed the front brakes without removing road wheels or jacking the front end up? Obviously this would make the task a lot quicker.
'67 S1.5 FHC, manual, maroon with black interior. Originally exported to Arizona but 'repatriated' in '89. Since converted to RHD and triple SUs.
#2 Re: Bleeding front brakes with wheels on
I'm not sure that it would.
The access would be very tight and you'd end up trying to get under the front of the car where I, for one, certainly don't fit.
Unless you have a really compelling reason not to, front up and wheels off is the way to go.
#3 Re: Bleeding front brakes with wheels on
Quite easy to do......just lift the bonnet plenty of access....Steve
rossbraithwaite
#4 Re: Bleeding front brakes with wheels on
well, since posting this I have done it both ways! It is 'possible' without removing road wheels but not very easy or pleasant! Quite hard to get the bleed tube onto the nipple and then fiddly to loosen the nipple with a spanner through the wheel spokes.
