#1 1966 ignition look wiring and function
Posted: Sat Apr 10, 2021 5:10 am
Good day,
I need some help in understanding my 66 ignition barrel and connection as the earlier cars were different or more simple.
On the 1966 car I have an ignition lock 34679 which has 4 terminals for 6 wires.
Earlier cars only had 2 terminals the brown/white and 2 whites on the other side. Turning key, current went through and ignition was on.
This LUCAS 34679 lock for 1966 cars also has the brown/white and the 2 whites and continuity is given when turning the key. This key only turns by 45° whereas the earlier barrels have a 90° turn.
But I wonder why the 2 brown/purple and the 1 brown/red are also connected to this ignition lock?
As I have no continuity from either of these and my Amp pointer dances to its maximum deflection when head light are on and also my ignition warning light goes off at about 900 rpm, where is used to turn off at 1.600 rpm.
I am wondering if there is a problem with the ignition lock. And what is the purpose of having those wires now at the ignition switch?
I already swapped the regulator twice and the 3AW switch is new. Voltage at Batterie when running is 17.4 V
Any feedback is welcome
Many thanks
Maikel
Many thanks
Maikel
