#1 Crome bead on the cantrail.
Posted: Mon Apr 26, 2021 8:28 pm
Hi how does the chrome bead fit to the cantrail on a series 1 2+2?
There is one clip at the bend above the A post but nothing else. Should there be more clips?
Also how is the cantrali attached to the body? Mine is by small ( 2mm) self tapers that screw through the outer seal channel. Should the cantrail be fitted before the seal channel?
