Clutch slave piston replace
Topic author - Moderator
#1 Clutch slave piston replace
Hi All.....nice write up on JagLovers....it been discussed quite a bit on the poor quality of the clutch slave piston seal......so if you haveing problems a simple upgrade/replacement https://forums.jag-lovers.com/t/clutch- ... ent/406515
#2 Re: Clutch slave piston replace
Thanks for that Steve
Good to know if I decide to re-do my slave cylinder....again....
#3 Re: Clutch slave piston replace
Maybee you need to check and make sure its still ok
