brake bleeding
rossbraithwaite
#1 brake bleeding
Post by rossbraithwaite » Mon Jun 07, 2021 3:38 pm
Hello All, apologies for the newbie question on a subject extensively covered on the forum. With regards to the textbook process for bleeding brakes; two people, hold pedal down while nipple is closed, release pedal etc.
If the S1 Girling calipers have the ball bearing correctly fitted under the bleed nipple should it work effectively as a non-return valve for brake bleeding? If so, is there any need for a non-return valve bleed tube? Or for the two person bleed technique?
At the bottom of pedal travel when fluid flow stops the ball bearing should drop back into position and prevent return fluid flow. Am I missing something?
Thanks, Ross
#2 Re: brake bleeding
Post by mgcjag » Mon Jun 07, 2021 8:24 pm
Hi Ross....i dont know about the ball in the bleed nipple......but it really isnt a big deal to bleed the brakes even single handed.....open nipple push pedal down....hold it down with a length of 4x2 wedged against the seat...close nipple.....repeat.....Steve
rossbraithwaite
#3 Re: brake bleeding
Post by rossbraithwaite » Mon Jun 07, 2021 9:12 pm
Thanks Steve, my question is why is it necessary to close the nipple for the pedal release stroke? The BB under the bleed nipple should prevent return. I have done as you describe on a Land Rover but that had no BB under the nipple.
#4 Re: brake bleeding
Post by abowie » Mon Jun 07, 2021 10:26 pm
rossbraithwaite wrote: ↑
I don't think that it does.
All you are doing is changing one sealing surface for another when the screw is tightened.
288gto
Russia
#5 Re: brake bleeding
Post by 288gto » Tue Jun 08, 2021 9:28 am
Andrew, the ones I've seen have a small spring pushing the "ball bearing" against the outlet hole so that it acts as a non return valve. My Fosseway brakes came with them but I'm m not convinced how effective they are. I bled mine using a combination of vacuum bleeder and traditional foot method.
Note to Ross the OP, mine a complete new system did take a lot of bleeding including slackening the union on the servo to get a good pedal. There's lots on here about bleeding the brakes.
#6 Re: brake bleeding
Post by mgcjag » Tue Jun 08, 2021 9:31 am
The OP gives the impression the ball bearing is a standard fit on the Girling caliper....he dosnt mention aftermarket bleed nipples......Steve
rossbraithwaite
#7 Re: brake bleeding
Post by rossbraithwaite » Tue Jun 08, 2021 10:14 am
yes, the BB under the bleed screw is standard on S1 brake calipers
#8 Re: brake bleeding
Post by christopher storey » Tue Jun 08, 2021 1:15 pm
I think some confusion is creeping in here : S1 original calipers are not Girling, but Dunlop . S2 calipers are Girlings .
rossbraithwaite
#9 Re: brake bleeding
Post by rossbraithwaite » Wed Jun 09, 2021 5:16 pm
Sorry, mea culpa. I meant the S1 Dunlop caliper
#10 Re: brake bleeding
Post by abowie » Wed Jun 09, 2021 9:03 pm
288gto wrote: ↑
The original ones don't. They just have a small dished section at the end of the screw.
288gto
Russia
#11 Re: brake bleeding
Post by 288gto » Thu Jun 10, 2021 12:53 am
Thanks Andrew, you learn something new every day, I know which ones you mean now. Without a spring, presumably you are just relying on gravity for it to act as a non return valve?
#12 Re: brake bleeding
Post by abowie » Thu Jun 10, 2021 8:24 pm
As I said, I don't think it does act as a non return valve.
All it does is gives you an annular sealing surface rather than a "needle and seat" one.
Presumably this doesn't give a real advantage as modern cars all use the "needle and seat" design.
