S2 Brake master cylinder reaction valve
#1 S2 Brake master cylinder reaction valve
Seeking guru with simple answer...I replaced my brake master cylinder using the new Lockheed 'made on the original tools'. I also had my servo rebuilt and have replaced all the vacuum hoses. The reaction valve now expels air with a hiss when you press the brake pedal with the engine running. The brakes still work once the hiss has happened. I removed the reaction valve and replaced with the one from the original master cylinder. Same thing happens. As far as I can see the diaphragm looks fine. Any ideas as to why this is happening? Things to check? Many thanks for your help. Rod
Rod Evans
1969 S2 DHC LHD
1969 S2 DHC LHD
#2 Re: S2 Brake master cylinder reaction valve
Liquids (or gases) make a hissing noise when a high pressure goes through a small aperture. If the hole for the air to go through were bigger, then it wouldn't make a noise. If both of your reaction valves were the same, then they'd probably make the same noise as air rushes back in.
