#1 E Type with XJ6 Cams - chatter
Posted: Fri Jun 18, 2021 9:36 pm
Hi, some advice please from you knowledgeable types.
I have a '67 E Type roadster 4.2 but unfortunately it doesn't have the original engine but that of a '73 XJ6 4.2.
During the restoration I stumbled across a genuine 4.2 E Type head and decided to fit that, having made the appropriate adjustments to the longer block (as discussed elsewhere on here). All went well and no problem with that.
The head did not come with cams but having checked the ones from the XJ6 they were perfect, with four holes for the sprockets, not two. I spoke to a few people/suppliers and checked on here. The advice was that the cams would work perfectly but the tappet gap will need to be increased from the 4 thou range (for E Type cams) to 12-14 thou (for the XJ6 cams). The cams had new bearings and were line bored. All this seems to be fine.
The car runs well but I have significant chatter from the cams to the extent that I cant put up with it. I've checked the gaps twice, made a few minor adjustments, but no significant noise improvements. I did have one valve which was (20 thou) too short, because I had one new valve seat fitted which was not cut in sufficiently (by allegedly expert engineers!!). Ive overcome this by grinding a small step in the shim so it sits snuggly on the top of the valve stem and does not rest on the spring top. All good.
So my question.... Would it be ok to reduce the tappet clearance to a compromise between the two settings, say 10 thou or less? I guess its a larger gap in the XJ6 due to cam profile, but I cant find any data on this. If the E Type manages on such small gaps there must be little heat expansion or contraction in tolerance, (unlike a pushrod engine), so I dont understand why such a large gap is necessary with the later XJ6 cam.
Any help or advice would be appreciated. BTW all the timing chains are properly tightened and no other noise is evident from the engine, the guts of which are all new.
Thanks in advance. I do appreciate your help and guidance on this forum. Its fantastic!
