#1 S3 diff dismantling tools
Posted: Tue Jun 22, 2021 5:10 am
Any advice?
Changing my FD from 3.54 to 3.07 with new oil seals all round.
According to the workshop manual the pinion "zero" mounting distance (C) is "4.312 in. (108.52 mm)". Checking this imperial/metric conversion, it is wrong, should be 109.52 mm!
My existing pinion setting is +9 (thou), so existing pinion mounting distance is 4.321 in. = 109.75 mm.
New pinion (Quaife via SNGB) mounting distance is 109.22 mm therefore, relative to the existing, it needs to be mounted 0.53 mm closer to the centre of the ring gear. To do this by the book I would remove the bearing and add shims underneath, where it presses into the casing.
To remove the bearing cup from the casing requires special tools. And if I disturb/renew the brg, any relative adjustment (as above) would be unreliable...
Alternatively I could retain (not disturb) the existing bearing (it looks ok) and just add required extra shims on top of it, i.e. between it and the head of the pinion.
Same difference?
Is there ways to remove the pinion brgs without the special tools?
Same difference?
