Hi everyone I have a 1966 S1 OT the indicators and full beam flash on the indicator stick have stopped working would welcome any suggestions and advice before I take it to a auto electrician.
MANY THANKS
Indicators
#2 Re: Indicators
The first thing to check is the relevant fuses . Not all cars are wired exactly the same, so you will have to look in your drop down dash panel to see which fuses may have been affected, but usually the headlamp flasher unit is fuse 1 and the indicator switch is fed by a purple wire from fuse 8 . It is also important to check that you have a good earth from the indicator/flasher switch casing
EDIT I should also have said that the headlamp flasher wire should be green and yellow
Last edited by christopher storey on Tue Jul 06, 2021 6:32 pm, edited 1 time in total.
#3 Re: Indicators
Hi Christopher thanks for the quick reply it’s very much appreciated I’ll have a look at them probably tomorrow now.I’ll let you know if I have any success. Thanks again
#4 Re: Indicators
Also worth checking the bullet connector block between the indicator stalk and the loom in case anything has dropped out!
#5 Re: Indicators
Thanks for that cactusman hopefully it’s one of these suggestions I’ll let you know. Thanks
