Rear Hub Spline Wear
mxke
#1 Rear Hub Spline Wear
Post by mxke » Wed Jul 07, 2021 1:03 am
I believe I know the answer, but would like confirmation - are the splines on this hub knackered?
Thank you in advance.
Mike
#2 Re: Rear Hub Spline Wear
Post by bitsobrits » Wed Jul 07, 2021 1:17 am
The first photo looks serviceable, as long as you can't rock the wheel back and forth (without the spinner in place), but the second photo looks like it could be a textbook example of very worn splines. Hopefully the wheels look better than the hubs or you will need to replace both.
mxke
#3 Re: Rear Hub Spline Wear
Post by mxke » Wed Jul 07, 2021 1:35 am
This car had a rough life. I think it’s breathing a sigh of relief as I slowly fix her up.
The wheels are in roughly the same shape as the hubs… :banghead:
