heater fan switch
paul j
#1 heater fan switch
Post by paul j » Mon Aug 09, 2021 6:37 am
Hi All, can anyone confirm the operation of the heater fan switch, i am getting a circuit to both top terminals when switch to fast speed, meaning i have power direct to green/blue and green/yellow at the same time. I have dismantled my heater fan switch, everything looks ok in there, and the black actuator looks like it should switch one side on slow, then disengage slow and engage fast on the other side possibly but this is not happening. To me power should be supplied via resistor only on slow position or direct to motor on fast position but not both at the same time ? Any help would be appreciated, thanks, Paul
68 1.5 2+2 Lhd-Rhd full resto
Joes66
#2 Re: heater fan switch
Post by Joes66 » Wed Aug 11, 2021 3:54 pm
Both at the same time is normal as far as I know on fast speed
My series 2 switch feeds both on fast
But one goes through a resistor so it just goes fast
Its seems strange but thats how mine is
Joe
1969 series 2 2+2
#3 Re: heater fan switch
Post by MarekH » Wed Aug 11, 2021 5:26 pm
paul j wrote: ↑
The current will take the easiest route, inversely proportional to resistance where there is a choice, so connecting both is not a problem. Virtually no current flows through the resistor as the short circuit connection across the resistor is so much easier.
paul j
#4 Re: heater fan switch
Post by paul j » Thu Aug 12, 2021 3:50 am
Thanks Joe and Marek for confirming this for me , first time for car electrics for me !!!! Appreciate the help, Regards Paul
