Hot key syndrome
#1 Hot key syndrome
My key in the ignition switch is getting quite hot after a longish drive, is it time to install a relay to drastically reduce the current flow through the ignition switch?
#2 Re: Hot key syndrome
Short answer yes......viewtopic.php?f=9&t=6885&hilit=Ignition+relay
#3 Re: Hot key syndrome
Thanks Steve, thought so, I am on it
#4 Re: Hot key syndrome
I did this upgrade recently. I wasn't getting a hot key but now I get a nice warm feeling from not running all that current through the somewhat delicate ignition switch.
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#5 Re: Hot key syndrome
#6 Re: Hot key syndrome
Just received my relays (incl a spare) in readiness for my upgrade.
1965 S1 4.2 FHC (early)
#7 Re: Hot key syndrome
Mine will be with me tomorrow - 40A 14VDC - Amazon (also a pair of them).
