#1 S1 Not Running / Misfire
Posted: Thu Aug 12, 2021 7:32 pm
Hello,
So I got in my car for a drive last weekend and when the car fired up it was misfiring badly with a lot of shake. I decided not to take it out and have been trouble shooting since. After the first run the car now does not really run anymore, although I do get the occasional short burst. It's strange as when I parked it a few weeks earlier it was running fine. The car has a mallory unilite distributor (electronic), an MSD Blaster 2 coil and ballast resistor. Here is what I have done so far
1. Cleaned fuel filter, tested fuel pump which is delivering 1.2 l/min @ 6psi
2. Checked float bowl valves which are moving freely
3. Checked compression which is +/- 120 psi on each cylinder (cold obviously)
4. Checked spark to each cylinder
5. Changed coil to a lucas type and bypassed the resistor
6. Changed distributor cap
7. Plugs are wet when removed
Plan to change the plugs as soon as the new ones arrive in the post. Only thing not changed is the rotor/shutter and the unilite sensor itself. These parts are quite hard to get in the UK hence why I haven't replaced these yet. However, given that there is a spark at each plug I'm not convinced (yet) these are faulty.
Any suggestions what to try next or what the cause of this could be?
Myles
Myles
