Automatic Transmission leak.
TiltyV12
#1 Automatic Transmission leak.
Post by TiltyV12 » Fri Aug 13, 2021 11:28 am
Hi Everyone,
I have a USA import and have a leak from the front where it meets the engine , I believe it is the seal.
Can i change it without fully removing the transmission
Any help appreciated. :thankyouyellow: :wavegreatbritain: :wavegreatbritain:
Brian Tilt
USA import 1973 automatic series 3.
TiltyV12
#2 Re: Automatic Transmission leak.
Post by TiltyV12 » Sat Aug 21, 2021 8:06 pm
Hi Guys ,
I have booked ramp space to do this job next week.
I have not received any response yet from forum.
Appreciate any advice if anyone has any advice.
Thanks again Brian :fingerscrossed: :fingerscrossed:
Brian Tilt
#3 Re: Automatic Transmission leak.
Post by mgcjag » Sat Aug 21, 2021 8:19 pm
Hi Brian...sorry you havent had a reply.....im not really up on S3 auto,s......but it would help if you posted a photo.....leak at the front? Engine oil or transmission fluid..........Steve
TiltyV12
#4 Re: Automatic Transmission leak.
Post by TiltyV12 » Sat Aug 21, 2021 8:43 pm
Hi Steve ,
Great to hear off someone 😊
Definitely transmission oil.
I believe it is from between the auto box and engine
and can put some photos on once on the ramp.
I believe I read something that you can move the box
back enough to change the gasket 🤔
Thanks again for your reply 👍
Brian Tilt
#5 Re: Automatic Transmission leak.
Post by mgcjag » Sat Aug 21, 2021 9:03 pm
Hi Brian....the gearbox sits at the rear of the bellhouseing.......but the torque convertor sits further forward and is full of oil.....sorry mate cant go any further....Steve
Geoff Allam
#6 Re: Automatic Transmission leak.
Post by Geoff Allam » Sun Aug 22, 2021 5:04 am
If it is definitely transmission oil the most likely leak is from the torque converter seal. Requires the transmission to come out.
Geoff Allam
driver
#7 Re: Automatic Transmission leak.
Post by driver » Sun Aug 22, 2021 5:13 am
Hi ,
I had a similar leak from my S3, it was the the front gearbox seal .its not an expensive repair just gently prise the old seal out and replace with a new one .
I took the gearbox out when doing my repair, this can be done without taking the engine out.
All the best ,
Rob Gill
v12 etype 2+2
TiltyV12
#8 Re: Automatic Transmission leak.
Post by TiltyV12 » Sun Aug 22, 2021 5:53 am
Hi Guys ,
Thanks for your replies.
I will update you fully when I have my car up on
the ramp this week.
Looks like I will have to remove the automatic
transmission.Advice on this welcome.
:yeahthat: :wavegreatbritain: :thankyouyellow:
Brian Tilt
#9 Re: Automatic Transmission leak.
Post by mgcjag » Sun Aug 22, 2021 7:43 am
Hi Brian....have a look here.....details on removeing v12 gearbox without engine.....The author Dick Maury is very well respected in the US......Steve http://www.georgiajag.com/Documents/V12 ... moval.html
TiltyV12
#10 Re: Automatic Transmission leak.
Post by TiltyV12 » Sun Aug 22, 2021 9:38 am
Hi Steve ,
Thanks so much this is really helpful.
I like to work to a plan , brilliant.
I can now study it before ripping it apart.
Thanks again :wavegreatbritain: :thankyouyellow:
Brian Tilt
