Fast Road camshaft conundrum!
Simonpfhc
#1 Fast Road camshaft conundrum!
Post by Simonpfhc » Thu Nov 09, 2023 6:23 pm
Hi all,
Looking for some help with setting valve clearances on “fast road” camshafts.
Some background…….
I’m doing some general maintenance work on a friends XK engine (actually in a 120) and checked the valve clearances. The exhausts are all around the 6-8 though range and the inlets are around the 4 thou range, but one is 2 thou and two of them 3 thou. So have removed the inlet cam to set them all to at least 4 thou. However, the owner informed me that the camshafts are “fast road” cams that were already fitted when he bought them. He has no record of where they cam from or who fitted them.
Both cams are of the 4-bolt variety. Normally in this situation, I would just remove them both and set them to factory correct 12 and 14 thou clearances for theses types of cams. However, they are not factory cams!
So the question…..do I set them to the larger 12 and 14 thou??
Both cams are definitely the later parabolic ones (the inlet is stamped C35556). They are also stamped KCJAG2 on the end flange.
Antone know these types of cams?
Are some reprofiled parabolic cams set with smaller valved clearances??
Any advice appreciated.
62 3.8 FHC
91 Porsche 928GT
#2 Re: Fast Road camshaft conundrum!
Post by mgcjag » Thu Nov 09, 2023 7:01 pm
Hi Simon....KC is probably Kent Cams... they do a Jag 2 camshaft....just beware that some fast cams also come with replacement tappets and gaps to suit...give them a call or look on their Web site..Steve
Simonpfhc
#3 Re: Fast Road camshaft conundrum!
Post by Simonpfhc » Thu Nov 09, 2023 8:25 pm
Hi Steve,
I think you’re spot on! I’ve just had a look on the Kent Cams website for the Jag2 camshaft and they state 8 thou and 10 thou valve clearances. I’ll give them a call in the morning.
Thanks so much.
62 3.8 FHC
91 Porsche 928GT
#4 Re: Fast Road camshaft conundrum!
Post by christopher storey » Thu Nov 09, 2023 10:14 pm
Unfortunately, unless my memory is leading me astray I have experience of these camshafts on a Series 1 4.2 ( not my car) and they were a disaster, digging a terrible hole in the torque curve at around 2250 - 2500 rpm . It was all some years ago so I will make a few calls tomorrow to refresh my memory, but on balance if i were you I would acquire a pair of standard cams and stick to standard clearances . It is very significant that in the whole 44 year life of the XK engine, Jaguar stuck to the 57/15/15/57 cam duration although they did from memory retard the whole timing by 4 degrees towards the end of the life of the engine, probably for emissions purposes
Last edited by christopher storey on Thu Nov 09, 2023 10:19 pm, edited 1 time in total.
#5 Re: Fast Road camshaft conundrum!
Post by abowie » Thu Nov 09, 2023 10:17 pm
The clearances for your cam will be specified by the manufacturer.
The clearances for the various iterations of the factory cams depend on the lobe profile and yours will be different from this.
For example, I have a "D Type" grind on the cams in my MK2. The manufacturer specified 8 thou clearances for both inlet and exhaust.
#6 Re: Fast Road camshaft conundrum!
Post by abowie » Thu Nov 09, 2023 10:19 pm
https://www.kentcams.com/part/JAG2
So 8 thou inlet and 10 thou exhaust.
Simonpfhc
#7 Re: Fast Road camshaft conundrum!
Post by Simonpfhc » Fri Nov 10, 2023 8:03 am
Andrew/Christopher, really appreciate your input, many thanks.
I totally agree, if it were my car, I would revert to correct cams.
Alas……
62 3.8 FHC
91 Porsche 928GT
Simonpfhc
#8 Re: Fast Road camshaft conundrum!
Post by Simonpfhc » Fri Nov 10, 2023 10:52 am
This engine keeps giving!!
Just removed the valve buckets and shims from the inlet side and found these:
Has anyone ever seen these before?
62 3.8 FHC
91 Porsche 928GT
rfs1957
#9 Re: Fast Road camshaft conundrum!
Post by rfs1957 » Fri Nov 10, 2023 10:56 am
This banter included some good nuggets that are relevant to this exchange.
viewtopic.php?f=3&t=16637&p=139236&hili ... ts#p139236
I never felt I got enough credit for publishing this technical diagram
which has to be accompanied by the question :
Now, exactly where on this map was your car short on horsepower ?
#10 Re: Fast Road camshaft conundrum!
Post by mgcjag » Fri Nov 10, 2023 11:01 am
Hi Simon...xk120 should be as our E types...but I did mention above iv heard that some after market cams come with replacement buckets that need fitting...Steve
Simonpfhc
#11 Re: Fast Road camshaft conundrum!
Post by Simonpfhc » Fri Nov 10, 2023 11:08 am
Well, I think I’ve found my answer - they are top-hat shims used in racing due to their low mass. They are accompanied with matched racing buckets. Nice.
Thanks for everyones input on this.
62 3.8 FHC
91 Porsche 928GT
