The self adhesive strip between my triangular air intake duct C17533 and the 3-trumpet intake C25266 has disintegrated. I got it from SNGB a few years back and maybe one should not expect more than a few years life from a bit of foam rubber.... but they are out of stock anyway. Does anyone have a recommendation of a good quality durable replacement?
Thanks all,
Air cleaner to plenum sealing strip - suggestions?
#1 Air cleaner to plenum sealing strip - suggestions?
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#2 Re: Air cleaner to plenum sealing strip - suggestions?
Jeremy : the best suggestion I can offer is to make your own - this sort of thing is usually available in various sizes and sections from craft , haberdashery or model shops
#3 Re: Air cleaner to plenum sealing strip - suggestions?
Yes, or try sticky backed draught excluder for doors or windows. B&Q sell it as do Amazon: https://www.amazon.co.uk/s?k=draught+ex ... _sb_noss_1
#4 Re: Air cleaner to plenum sealing strip - suggestions?
I will try that. Thank you both.
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
