#1 New SU float needles and seats
Posted: Fri Oct 08, 2021 4:37 pm
Hi all
I'm just about to replace the float needles with a new Burlen kit (along with fitting unsinkable foam floats as a precaution against ethanol after the solder on one of my brass ones gave way - on E5...). I've taken the first old one out and two interesting points. Firstly the tip on the old one looks to be intact but has stretched/lifted slightly from the needle. Second, and i've measured this a few times, the new one is shorter by 0.5mm overall. Put together this will mean the valve is closing with the fuel level about 1mm higher than before. I don't know how sensitive this is - the arms are set to the correct 7/16". Will I need to retune the carbs/reset the base of the jets?
