First foray into porting
#1 First foray into porting
Post by abowie » Fri Oct 22, 2021 5:15 am
Armed with Des Hamill's XK Engine tuning book and a sense of trepidation I have embarked on the head for my MK2.
Brenton my machinist's comment "Nah mate you can't stuff it up."
So I made a brass mandrel punch, heated the head up with the oxy torch and knocked the valve guides back to give some room.
After 3 hours:
inlet and exhaust guide bosses gone
exhaust roof lip relieved
inlet port side waist flattened and opened up a smidge
Exhaust post exit.
Exhaust port throat.
Inlet port entrance.
Inlet port throat.
Simonpfhc
#2 Re: First foray into porting
Post by Simonpfhc » Fri Oct 22, 2021 6:55 am
Hi Andrew,
Very neat work, well done. Will be interesting to hear what difference it makes.
Presume this is part of of un upgrade that includes other aspects of the engine - what other mods are you planning and do you have a target power figure you are after?
Cheers,
62 3.8 FHC
91 Porsche 928GT
#3 Re: First foray into porting
Post by abowie » Fri Oct 22, 2021 7:47 am
No specific HP figure, but want to make my MK2 "sprightly" rather than the current "sluggish" with its stock 3.4 and a 5 speed Toyota Supra box.
Spec is 4.2L short stud block relined back to standard and blueprinted. Stock flywheel judiciously lightened. My mild head work. D type cams. Twin 2" SUs mounted on the stock inlet manifold. 9.5:1 compression.
And I'm fitting big inlet valves.
I reckon I currently have maybe 150Hp. Looking for maybe 70 to 80 more.
#4 Re: First foray into porting
Post by abowie » Fri Oct 22, 2021 7:52 am
I was surprised at how easy this was.
As always, 9/10ths of the job is overcoming the trepidation and just getting on with it.
Plan is to get it flow tested and then there's inevitable blending and fine work to do, but as a total beginner it was not difficult to get to this point.
max-it-out
#5 Re: First foray into porting
Post by max-it-out » Fri Oct 22, 2021 10:00 am
One could argue that the main factor in limiting the flow of gases is the size of the valve openings , and the shape of the ports / manifolds is less important . However , porting should be a lot cheaper than fitting a new big valve head , so it will be interesting to see the results . :?:
1968 series 1.5 roadster
mark10337
Switzerland
#6 Re: First foray into porting
Post by mark10337 » Fri Oct 22, 2021 10:40 am
I know that feeling! Hat's off to you or should that be valve guides out? :smile:
I remember reading, not sure if it was Des Hamill's book or not, that the inlet passages should not be totally smooth. Some turbulence from the walls is desirable in order to ensure a good mixture of air and fuel.
Good on you. I need to bite the bullet and do my valve timings.
-Mark
steve3.8
#7 Re: First foray into porting
Post by steve3.8 » Fri Oct 22, 2021 1:07 pm
You don't mention valves Andrew ,so i guess you are maybe using standard as supplied ?.
Having gone to the trouble of doing a port flow, buying better quality valves are worthwhile as part of the port flow process.
Look up Race Engineering Components - G&S Valves - they stand alone when put alongside standard valves , it's a company most race engine builders use.
http://www.gsvalves.co.uk/
Steve3.8
64 3.8 fhc, 67 4.2 fhc
#8 Re: First foray into porting
Post by abowie » Fri Oct 22, 2021 9:56 pm
I'm going to fit the big inlet valves out of the S3 XJ6. 1.8715".
#9 Re: First foray into porting
Post by christopher storey » Sat Oct 23, 2021 10:06 am
I don't know whether this applies on XK engines , but on A and B series BMC engines one of the mods which can assist flow greatly is to use 3 angle valve seats and valves
steve3.8
#10 Re: First foray into porting
Post by steve3.8 » Sat Oct 23, 2021 3:18 pm
This photo may explain better , these are 1.875" inlets . The REC on the left and a commonly supplied on the right.
Steve3.8
#11 Re: First foray into porting
Post by abowie » Sat Oct 23, 2021 9:22 pm
Yes I will be doing that. Has a surprisingly large impact on valve flow early in the opening period.
