Running-in oil
carlv12
Spain
#1 Running-in oil
Post by carlv12 » Fri Oct 08, 2010 9:20 am
Hello,
I am restoring/repairing my E Type V12 engine changing pistons, liners, rings, inlet and exhaust valves, valve inserts, bearings, timing chain and parts, cylinder head and much more parts.....
Does it make sense to use first a running-in oil and after 500 miles the correct 20W50 or 20W50 mineral oil?
Thank you and best regards from Valencia
Carlos
D COUPE
Post by D COUPE » Sat Oct 09, 2010 12:42 pm
Makes perfect sense. A thousand mile on running in oil is recommended on most rebuilds
ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
carlv12
Spain
Post by carlv12 » Sun Oct 10, 2010 12:39 pm
Thank you for the answer. But I still do not know what exaCTLY MAKES THE RUNNING-IN OIL BETTER THAN a good mineral 20W50. Please try to explain. Thank you
Carlos
D COUPE
Post by D COUPE » Sun Oct 10, 2010 12:52 pm
It is my belief that the running in oil contains no detergents. Its allows the cam shaft and rings to bed in while protecting the other major components
Try Millers oils in Google
Post by Heuer » Sun Oct 10, 2010 12:53 pm
Carl
Ordinary engine oil is perfectly OK although you should probably stick with mineral rather than synthetic and opt for 10W40. Change the oil and filter after 1,000 miles or whatever Jaguar recommend.
