#1 Starter failure ....!
Posted: Wed Oct 20, 2021 10:46 am
by Polse7317
I have since some days a intermittent issue when i start the engine :
I hear a "click" when i push the starter button at the dash once or until 8 trys and then the starter works engage....
I have checked at the connector thinking it was something loosed but found nothing .
What can be the culprit ? Starter relay ?
My starter is a "almost new" one from SNG B :shrug:
#2 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 11:36 am
Hi Yves...i assume you have a seperate starter solonoid......check it out.....Steve
#3 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 3:15 pm
by politeperson
Have you got the spacer ring in place?
#4 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 4:47 pm
by malcolm
Sounds like solenoid to me. Had that dreaded click on my TR4 when solenoid was dodgy
#5 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 4:56 pm
by Polse7317
Spacer ring??? , separate solenoïd I think so .... :scratchheadyellow: my starter seems to have two components gathered
How can i check the solenoïd?
#6 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 5:25 pm
Is you starter an aftermarket high torque unit?....Steve
#7 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 5:37 pm
by Polse7317
I think so but i must confirm at SNG
#8 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 5:59 pm
The unit by the battery is a starter solonoid and your starter motor also has a starter solonoid by the looks of it....you need to start testing the electrics....your start button operates and you here a click.....so whats clicking....is it the solonoid by the battery......does this then extent the power through to your starter motor?.....Steve
#9 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 6:10 pm
by Polse7317
I have to test that , but need of course someone by the engine to diagnose where the click comes from....!
I 'll post when i'll know :salute:
#10 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 6:39 pm
Yves.....disconnect the battery.........switch on ignition.....press in start button and hold in place with a stick or similar......go to the battery. ...just touch on the disconnected connector.......you should hear the clicking....Steve
#11 Re: Starter failure ....!
Posted: Wed Oct 20, 2021 7:45 pm
by Polse7317
:fingerscrossed: 'll try that tomorow. May be i can squeeze the connector near the battery if what i thought is a solenoid
old photo below but showing the " connector solenoid?"
#12 Re: Starter failure ....!
Posted: Thu Oct 21, 2021 3:51 pm
by Polse7317
The wiring to the starter is direct from the battery the big wire is connected on the same "bolt" on the old solenoid . So i think that it's my starter which is not operating sometimes . I don't think i can replace the solenoid "binded" close to the starter . i'll resove to replace it .
I am not happy to do that because i have to take out the central console for acces to the upper nut of the starter.... :roll:
#13 Re: Starter failure ....!
Posted: Thu Oct 21, 2021 4:40 pm
Hi Yves...i thought thete was an access hole to get to the top bolt without removeing center consul.....have a good look under the bulkhead carpet.....think its a large grommet/removable panel.....Steve https://themotorphile.com/2010/11/22/ja ... n-starter/
