!/4 light window seal (FHC)
#1 !/4 light window seal (FHC)
Hi should the rubber seal be glued completely to the bodywork or just in the groove .
S1 4.2 RHD Bryan
#2 Re: !/4 light window seal (FHC)
Dosnt need glue it fits in the retainer channel.....Steve
#3 Re: !/4 light window seal (FHC)
Mine dose not new from well known supplier . It is quite soft and the channel on the body is only a sort of a square recesses and will not hold it .
S1 4.2 RHD Bryan
#4 Re: !/4 light window seal (FHC)
Then you have two options....fit a correct channel........or make do by glueing where needed.....Steve
