#1 XKE 1969 clutch command
Posted: Fri Oct 29, 2021 5:34 pm
by JO-44
Hello everyone,
on my Jag type XKE 1R11489 from 11/14/1969 I hadn't been paying attention so far, but I looked at the assembly of the clutch slave cylinder and the control rod.compared to the inventory parts I do not have the return spring. Clutch Return Spring Plate C5178 and fork return spring C5120. I don't know if it's specific on this model but it looks weird to me. how to prevent Clutch Release Bearing from staying in contact in this case?
#2 Re: XKE 1969 clutch command
Posted: Fri Oct 29, 2021 5:36 pm
by tinworm
Its the same arrangement on S1-S2 so I don't know what you are asking ?
Barrie
#3 Re: XKE 1969 clutch command
Posted: Fri Oct 29, 2021 6:06 pm
For a short perion Jaguar used a clutch slave cylinder that ddint use an external return spring....the cylinder was self adjusting......they stoped useing this and reverted back to a cylinder with an external spring that needed agjusting.....details are in tbe service manual and this posf is worth looking at....Steve viewtopic.php?f=3&t=14977&p=124923&hili ... ic#p124923
#4 Re: XKE 1969 clutch command
Posted: Fri Oct 29, 2021 10:18 pm
by JO-44
exhibit 17 and 18 that I don't have on my car.
Thanks to Steve for showing me the link to consult
#5 Re: XKE 1969 clutch command
Posted: Sat Oct 30, 2021 9:02 am
by Red Kite
#6 Re: XKE 1969 clutch command
Posted: Sat Oct 30, 2021 9:12 am
by JO-44
Thanks Gerry, so if I understand correctly the hydrostatic long does not need a return spring?
#7 Re: XKE 1969 clutch command
Posted: Sat Oct 30, 2021 9:52 am
by JO-44
mgcjag wrote:
Sat Oct 30, 2021 9:23 am
To be honest and the difficulty in replaceing a worn out thrust bearing i would advise anyone to fit an external return spring and adjust correctly at regukar service intervals.......Steve
yes, disassembling the engine and gearbox to replace a simple clutch release bearing is not my favorite sport. So I am going to adjust a return spring, this is the advice of an experienced sage.
#8 Re: XKE 1969 clutch command
Posted: Sat Oct 30, 2021 10:27 am
by Gfhug
Yes, Steve knows his onions :lol:
