Hello everyone,
on my Jag type XKE 1R11489 from 11/14/1969 I hadn't been paying attention so far, but I looked at the assembly of the clutch slave cylinder and the control rod.compared to the inventory parts I do not have the return spring. Clutch Return Spring Plate C5178 and fork return spring C5120. I don't know if it's specific on this model but it looks weird to me. how to prevent Clutch Release Bearing from staying in contact in this case?
XKE 1969 clutch command
#1 XKE 1969 clutch command
- Attachments
- MOTEUR_3.jpg (255.2 KiB) Viewed 4086 times
JO-44
1954 Jag XK120(678344)- 1969 Jag XKE 4,2(1R11489) - 2004 Jag XK8 4,2
#2 Re: XKE 1969 clutch command
Its the same arrangement on S1-S2 so I don't know what you are asking ?
Barrie
Barrie
#3 Re: XKE 1969 clutch command
For a short perion Jaguar used a clutch slave cylinder that ddint use an external return spring....the cylinder was self adjusting......they stoped useing this and reverted back to a cylinder with an external spring that needed agjusting.....details are in tbe service manual and this posf is worth looking at....Steve viewtopic.php?f=3&t=14977&p=124923&hili ... ic#p124923
#4 Re: XKE 1969 clutch command
exhibit 17 and 18 that I don't have on my car.
Thanks to Steve for showing me the link to consult
- Attachments
- CLUTCH COMMAND_1.jpg (48.03 KiB) Viewed 4039 times
JO-44
#6 Re: XKE 1969 clutch command
Thanks Gerry, so if I understand correctly the hydrostatic long does not need a return spring?
JO-44
#7 Re: XKE 1969 clutch command
yes, disassembling the engine and gearbox to replace a simple clutch release bearing is not my favorite sport. So I am going to adjust a return spring, this is the advice of an experienced sage.
JO-44
#8 Re: XKE 1969 clutch command
Yes, Steve knows his onions
