#1 Fitting door cards
Posted: Tue Nov 23, 2021 12:07 pm
by phoenix
S1 FHC 4.2
Hi I am just fitting the door cards and related chrome strips .The lower card seems like it should have bend and cover part of the hinge (which has hole for clip . OK yes I can bend the door card itself but I don't think the chrome strips will bend. Have I got the correct cards . They were ordered from one of the biggest Jaguar parts supplier which already has my car saved for ordering . Thanks
#2 Re: Fitting door cards
Posted: Wed Nov 24, 2021 12:18 pm
by phoenix
Looking at photos on line they stay straight and just stick out.
#3 Re: Fitting door cards
Posted: Wed Nov 24, 2021 1:24 pm
by Allrand
They stay traight along the bottom but bend away to follow the door line along the top, & extend beyond the front door line to just short of the A post, covering the hinge area, they don't attach to the hinge. There should be a short kinked piece of chrome trim along the downward sloping top edge beyond the widow frame line toward the A post.
#4 Re: Fitting door cards
Posted: Wed Nov 24, 2021 1:33 pm
by rswaffie
On my late 63 fhc, both the upper and lower chrome trim bend to follow the bend in the door card, as per above post. The door card is scored to make the bend/curve towards the a post easier.
#5 Re: Fitting door cards
Posted: Wed Nov 24, 2021 3:54 pm
by Allrand
That's interesting. My new lower chrome strips from sng were straight (originals card & chrome were missing) so I kept the botom edge of the card straight ito match the bottom of the door. It wouldbe intetesting to see some original pics.
#6 Re: Fitting door cards
Posted: Wed Nov 24, 2021 4:54 pm
Look at the factory fit section for original details of 3.8 and 4.2 cars....Steve
#7 Re: Fitting door cards
Posted: Sat Nov 27, 2021 1:14 pm
by Allrand
Didn't find anything in Factory Fit, but in all other pictures I've seen the lower chrome trim looks straight.
#8 Re: Fitting door cards
Posted: Sat Nov 27, 2021 7:16 pm
by ysmalkie
Very original OTS 1E 10146 OTS '65
You can see rest of the photos on BaT:
I think the bottom is straight, however the top edge trim is to fix the bend angle..
Tadek
#9 Re: Fitting door cards
Posted: Sun Nov 28, 2021 4:13 pm
by Geoff Allam
Tadek, would it be possible to provide a link to that car or an approximate date to make searching for it easier?
#10 Re: Fitting door cards
Posted: Sun Nov 28, 2021 8:54 pm
by ysmalkie
There were a couple of them - I do not have the links.
However, I can give you access to my google drive with photos of 5 S1 4.2 original e-types.
I collect photos of original e-types - although my interests lie in the late 3.8 territory, some features are the same as early 4.2.
Here you go - please let me know when you download them - I will take the file away then.
Offer is for everyone, download asap :-).
Tadek
#11 Re: Fitting door cards
Posted: Sun Nov 28, 2021 9:09 pm
by Geoff Allam
Downloaded. Thanks for that. Geoff.
#12 Re: Fitting door cards
Posted: Tue Jun 21, 2022 8:30 pm
by Heronscourt
Not sure if you resolved this issue but here’s my solution to card fit. When I made the cards from 2mm white board MDF ( white side to the frame to help damp resistance ) I scored the back of the card on a line from the bend in the front top chrome to a point 60 mm from the from bottom front edge of the door. This enabled the the door card to bend easily to follow the top edge of the front of the door whilst allowing the bottom edge to stay straight. The chrome strip at front bottom does benefit from a slight bend but only the last 80 mm and very little. That is why the clip with two lugs holding the front of the trim is a slide fit in the trim instead of the special rivets. Otherwise the trim would keep popping off the rivet
