#1 Banjo Washers - Fibre or Aluminium ?
Posted: Wed Dec 01, 2021 6:44 pm
In follow up to my previous post “SU Overflow Pipe” - many thanks for the replies, but a further associated issue has arisen.
We have now fitted the SU Overflow pipe to the rearmost SU Carburettor on the 4.2 Series 1 2+2 and successfully managed to get the Banjo of the Overflow pipe to clear the top moulding of the Float Chamber lid, using the washers in the correct sequence.
I now realise the critical importance in the requirement to ensure the Serrated Fibre Washer is placed against the Lid to ensure an air passage - and presumably the petrol in an overflow situation - to track up around the cylindrical body of the Float Chamber Lid Bolt and out of the “overflow” pipe to ensure an air breathing path. I struggled to find any reference in formal documentation as to how important it was that this Serrated Washer was used as if the air passage was blocked by the use of a normal washer to be tight around the bolt, the SU potentially would not operate correctly if the fuel could not enter the Chamber correctly due to air pressure in the Chamber not being vented which would also cause fuel starvation assuming it could start in the first place. A very important washer !
I have digressed. So - carb choke all fixed, carb reattached and pipes coupled up. The original main fuel line to all three carbs on this particular car used Aluminium washers on each side of the Banjo bolts.
My official original 1960s Jaguar Spare Parts Catalogue identifies these washers as C.11489 Washer (Fibre) on Banjo Bolt (AUC. 2141). I ordered these Fibre Washers from my usual big supplier (their part number was AUC2141*) and received some red fibre washers. However on turning on the ignition one of the Banjos leaked petrol badly. The car has a later electronic SU petrol pump and the original aluminium washers did not leak before.
The mystery to me is Aluminium washers were originally fitted to his car and why other Suppliers - such as the one near a certain Southern Airport with a nice detailed parts catalogue, although I never use them - do show these specifically as “Aluminium Washer on Banjo bolt SJ5138 (C 11489).
Even the SU Spare Parts and Specification Catalogue shows on the HD Type Carburettor page that the Banjo Washer as part number AUC 2141, but their illustration number of 47 has an asterisk to show that “Alternative aluminium Washer AUD 2374” can be used. I expect the soft aluminium washer deforms to seal and would be a “one only use item”.
So, which is correct or was there a change over from Fibre to Aluminium ?
