rear window chrome trims
#1 rear window chrome trims
Hi has anyone had problems fitting the rear window chrome trims to the rubber, mine keep jumping out and seem not wide enough to stay in the rubber thanks ron.
#2 Re: rear window chrome trims
Yes I have the same problem, mine won't stay dowm in two spots, one at the top & one at the bottom. Probably the trim shape is not exact. Only solution is to glue it down, which I'm reluctant to do.
Randall Botha
'64 3.8 fhc & '51 Mk 7
#3 Re: rear window chrome trims
hi yes i thought about gluing but not keen on the idea thanks for reply ron.
