Fhc window outer seals
phoenix
#1 Fhc window outer seals
Post by phoenix » Thu Jan 20, 2022 9:57 pm
Hi is there an easy method of fitting the seals around the outer edge of an S1 fhc window frame and the upright quarter light frame. I just cannot seem to get the to drop in .
S1 4.2 RHD Bryan
rossco_j
#2 Re: Fhc window outer seals
Post by rossco_j » Fri Jan 21, 2022 2:11 am
Hello Bryan,
If you are referring to the seal in the photo below. It's a 2+2 door but process should be same. I started at the top corner & fed the rubber into the channel using some CRC silicone spray as lube to slide the rubber along.
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
https://rossjohnsonphotography.zenfolio.com/
phoenix
#3 Re: Fhc window outer seals
Post by phoenix » Fri Jan 21, 2022 1:22 pm
I will give it a try but I have already tried grease .
S1 4.2 RHD Bryan
#4 Re: Fhc window outer seals
Post by Series1 Stu » Fri Jan 21, 2022 8:42 pm
Try red rubber grease.
Is that seal fitted the correct way around?
