#1 Fhc window outer seals
Posted: Thu Jan 20, 2022 9:57 pm
by phoenix
Hi is there an easy method of fitting the seals around the outer edge of an S1 fhc window frame and the upright quarter light frame. I just cannot seem to get the to drop in .
#2 Re: Fhc window outer seals
Posted: Fri Jan 21, 2022 2:11 am
by rossco_j
Hello Bryan,
If you are referring to the seal in the photo below. It's a 2+2 door but process should be same. I started at the top corner & fed the rubber into the channel using some CRC silicone spray as lube to slide the rubber along.
#3 Re: Fhc window outer seals
Posted: Fri Jan 21, 2022 1:22 pm
by phoenix
I will give it a try but I have already tried grease .
#4 Re: Fhc window outer seals
Posted: Fri Jan 21, 2022 8:42 pm
by Series1 Stu
Try red rubber grease.
Is that seal fitted the correct way around?
