Correct plugs with 123 ignition.
Stevejaguar
#1 Correct plugs with 123 ignition.
Post by Stevejaguar » Fri Jan 21, 2022 8:02 pm
Hi, which are the correct plugs to use on my series 1 4.2 which has a non bluetooth 123 distributor?
I have been using BP5ES.
#2 Re: Correct plugs with 123 ignition.
Post by rswaffie » Fri Jan 21, 2022 8:33 pm
I’ve been using the BPR5ES plugs on my 3.8 with non-Bluetooth 123. No issues noted.
S1 3.8 FHC Opalescent Golden Sand with Tan Trim 8895**
Now enjoying my diy nut ‘n’ bolt restoration. :swerve: :wrench: :hammer: :fingerscrossed:
#3 Re: Correct plugs with 123 ignition.
Post by malcolm » Sat Jan 22, 2022 9:43 am
I'm on non-bluetooth 123 and it never occurred to me I might need to put different plugs in. Runs fine.
