Block drain
max-it-out
#1 Block drain
Post by max-it-out » Thu Feb 10, 2022 10:40 am
Just noticed there doesn`t seem to be a drain tap fitted to the block , but there is a nut in a similar position under the exhaust manifold which could be a drain plug . Also , can`t find any engine no. on the block . Car is a `68 , is this correct ? Thanks . :salute:
1968 series 1.5 roadster
#2 Re: Block drain
Post by rswaffie » Thu Feb 10, 2022 10:45 am
The engine number should be stamped on the block above where the oil filter attaches (if the S1.5 is the same as my 3.8)
#3 Re: Block drain
Post by mgcjag » Thu Feb 10, 2022 10:47 am
Hi Mark........yes a drain bolt replaced the drain tap....not sure when......engine numbers on engine above the oil houseing then later changed to being on the egde of the block next to the dipstick where the bellhouseing mates to it....Steve
Philk
#4 Re: Block drain
Post by Philk » Thu Feb 10, 2022 3:19 pm
The drain tap was replaced with a "drain plug" (C31616) as per Service Bulletin B.69 (published in June 1969). Once you've identified your engine number, those quoted below should be of assistance
1964 S1 3.8 OTS
AshM
#5 Re: Block drain
Post by AshM » Tue Feb 15, 2022 10:19 pm
Is it worth fitting a drain tap? Any benefits of doing this?
Would value any views?
Ash
Series 2 FHC 1970
1R 20607
#6 Re: Block drain
Post by abowie » Tue Feb 15, 2022 11:41 pm
Ash
I personally don't like them. Anything that can fail and dump all of your coolant before you notice it is a bad thing IMO.
I replace them with plugs.
#7 Re: Block drain
Post by mgcjag » Wed Feb 16, 2022 8:30 am
Agree with Andrew.....a simple plug is best.....Steve
Jeremy
#8 Re: Block drain
Post by Jeremy » Wed Feb 16, 2022 10:26 pm
:yeahthat:
My new RadTec radiator came with a screw-in plug and I didn't bother refitting the original tap, pretty little thing though it was. The tap had a corroded and weakened spring, and (despite lapping the conical surfaces) I never got it to seal securely.
Jeremy
1967 S1 4.2 FHC
AshM
#9 Re: Block drain
Post by AshM » Thu Feb 17, 2022 6:23 pm
Thanks gents.
Wise words, as always.
Will leave my block plug exactly as-is then!
Ash
Series 2 FHC 1970
1R 20607
