'Rear Window' switch
Stuart.C
#1 'Rear Window' switch
Post by Stuart.C » Tue Mar 01, 2022 3:23 pm
Hi All. Sorry for the seemingly simple question however I've searched on here and elsewhere on the internet and I can't seem to find the answer. Is the far right switch on the switch panel (1970 S2 2+2) marked 'Rear Window' for a heated rear screen? It doesn't appear to do much.
Many thanks
1970 S2 2+2 | 2001 DB7 Vantage | 2002 911 C4S | 1993 Skyline R33
1991 CRX Vtec | 2013 RS4 Avant
#2 Re: 'Rear Window' switch
Post by Gfhug » Tue Mar 01, 2022 4:54 pm
Stuart, yes it is. There is an inline fuse of 15 amps (irrc) behind the drop down panel that my need replacing if your rear window heater isn’t working. Also a good check of all connections along the way may show up an open circuit. On mine one of the wires attached to the rear window was open circuit and I had to make up a new connection.
Do you have the owners manual with the wiring diagrams?
See also the topic listed below by “mgcjag” that’ll help a lot.
Stuart.C
#3 Re: 'Rear Window' switch
Post by Stuart.C » Tue Mar 01, 2022 5:04 pm
Thats very helpful - thanks. I've downloaded the diagrams that were posted up on here so I will work through that. I don't have an original hard copy but I think the downloads will suffice.
#4 Re: 'Rear Window' switch
Post by Gfhug » Tue Mar 01, 2022 5:18 pm
Stuart, please read the comments in red from our administrator Heuer:
viewtopic.php?f=16&t=700
https://jec.org.uk/shop/e-type-3-8-4-2- ... ice-manual
Well worth the money
