Availability of original tie straps
#1 Availability of original tie straps
Does anyone know whether the original or after market cable ties to the space frame are still available and if so who sells them.
#2 Re: Availability of original tie straps
The straps are available from most of the suppliers - I’m sure I got mine from SNG. If you have an early car, the studs should be white (not black)!and these are very hard to find. I had to order online from a small hardware store in the US to get them.
Edit: looks like sng can get the white studs now.
https://www.sngbarratt.com/English/#/UK ... 5cc4523012
#3 Re: Availability of original tie straps
Yes, it may be worth contacting SNG since I was able to buy a "concours" strap kit from them which not only had white studs but also had a rubber-based strap which could (a) stretch a bit and (b) would not cut into the paint on the frames like the standard plastic strapping kit can do. It works very well.
The part number for that is C17001/2/1.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#4 Re: Availability of original tie straps
Hi, thanks for that. I managed to source the correct ones (with the white buttons) locally from Norman Motors here in London.
#5 Re: Availability of original tie straps
#6 Re: Availability of original tie straps
