Heat shield material (ASBESTOS)
Thim
Norway
#1 Heat shield material (ASBESTOS)
Post by Thim » Fri Apr 29, 2022 3:24 pm
Hey, Originally the E had asbestos plates to take the heat gradient on the exhaust heat shields. I'm now looking for a replacement material for the large middle exhaust heat shield below the silencers.
I have found a material called "Steni Masterboard" that is meant for house heating cables. (not very high temps) - I think it might work anyways, since it's fire resistant.
Do anyone have a better tip or advice?
Jaguar E-type s1, 1967 2+2. Under restoration by myself, slowly seeing the light at the end of the tunnel 👍
mtnjag
#2 Re: Heat shield material (ASBESTOS)
Post by mtnjag » Sat Apr 30, 2022 12:50 pm
What about the shields sold by SNG, Moss, and others i guess. Do the have insulation? I know the reservoir shield does.
Also, if your original is in good codition you could use a high temp adhesive and cover the asbestos with a woven foil backed heat insulating material. Available from “racing” suppliers in a roll, I got an 18” roll i believe, in the US like Pegasus, Summit Racing, Jegs,…. You could use the material alone if you have a bare shield and just rivet it to the metal. Tough stuff. I glued it to the orig shield encapsulating the asbestos. Been good for 25 years.
https://www.pegasusautoracing.com/produ ... oduct=1832
This is a link for non-adhesive backed. Also have adhesive backed. Good to 2000 dagrees!
Layne
Car #876005, 62 OTS
Thim
Norway
#3 Re: Heat shield material (ASBESTOS)
Post by Thim » Sun May 01, 2022 8:01 am
I know SNG sells, I was hoping to save some cash and reuse the old plate. I just need something to absorb the heat. The old asbestos is powder and saw the trash can many years ago :(
Thx for the tip :)
#4 Re: Heat shield material (ASBESTOS)
Post by mgcjag » Sun May 01, 2022 8:03 am
Hi Thim.....the board you mentioned appears to be ok....also look at the insulation boards that are installed on walls where you fit a wood burning stove....Steve
mtnjag
#5 Re: Heat shield material (ASBESTOS)
Post by mtnjag » Sun May 01, 2022 3:08 pm
What about using the material i mention riveted or glued to your existing shield without the powdered asbestos.
You saved the metal portion?
Layne
Car #876005, 62 OTS
