I've just begun assembly of the wishbones onto the diff and cage but thought I'd check that the special bolts would fit without problem.
1. I don't quite understand why the unthreaded portion of the bolt doesn't extend the whole length of the bush. Is the bolt wrong? If I fit it then there will be threaded portion under the bush which doesn't quite seem right.
2. There is counterbore in the wishbone at the head end of the bolt. Should the head be pulled into this when you tighten it so that it doesn't foul the hub carrier? The hole looks round whereas if that was the case you might expect it to be hexagonal.
Thanks for your help.
