car original engine and gearbox where can I check
#1 car original engine and gearbox where can I check
Hi where can I find out if the car S1 I am building has the original engine and gearbox . I think the bellhousing is wrong because it has an inspection hole on the left on top.
S1 4.2 RHD Bryan
#2 Re: car original engine and gearbox where can I check
This info is normally on the Heritage Certificate. You need to provide the chassis number.
Is the data plate not on the car?
#3 Re: car original engine and gearbox where can I check
Jaguar Daimler Heritage Archive 01926 895284 were very helpful when I bought mine.
ATB
Andy
ATB
Andy
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
1970 S2 FHC
#4 Re: car original engine and gearbox where can I check
Yes I thought so . I will tell the owner. Thanks
S1 4.2 RHD Bryan
#5 Re: car original engine and gearbox where can I check
A quick initial and decent indicator is the ID tag on the right sill extension in eng compartment. It will have eng number and trans number, chassis…. Yes it could be a restamp but unlikely unless the car has bee restored previously. Heritage cert will rule of course.
Trans number is stamped on the top cover of the trans. If its a 4.2 S1 it has an insp hole at flywheel on left upper side. There’s a TDC mark on the flywheel that can be viewed there. Not sure on the Moss box, Ill check mine later if no one confirms.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#6 Re: car original engine and gearbox where can I check
The inspection hole on the bell housing goes way back - pre war? Disappeared with the S2 introduction I believe.
Barrie
Barrie
#7 Re: car original engine and gearbox where can I check
JHT will not tell you what the numbers were. Usually they will merely confirm, or deny, that the numbers you give them are those originally fitted, or not as the case may be. In other words, you must give them the numbers that you find on the car before they will comment. Incidentally, if you still have the enigne in pieces both the crank and the flywheel should have the number stamped somewhere ( usually on the periphery of the flywheel IIRC)
