Reaction Valve
bubble
#1 Reaction Valve
Post by bubble » Fri Nov 05, 2010 6:15 pm
Forgive me for being Dumb but will the brakes need bleeding after fitting a new Reaction Valve.Thanks Gary.
Post by Heuer » Fri Nov 05, 2010 9:23 pm
Brake fluid is cheap and bleeding is easy. Fluid should be changed every two years anyway. I use a Mity-vac which helps enormously when single handed.
e-bygum
Post by e-bygum » Fri Nov 05, 2010 11:04 pm
The Reaction Valve is part of the vacuum circuit not the hydraulic circuit so no bleeding should be required.
'71 S3 2+2
bubble
#4
Post by bubble » Sat Nov 06, 2010 12:33 am
Thankyou for your help
