#1 Leaking fuel tank pickup plate
Posted: Tue Jul 12, 2022 12:45 pm
I've had a longstanding problem of petrol making its presence felt in the cabin (just a faint whiff) and when lifting the spare wheel boot board (a somewhat more pungent whiff). And dissolved paint on the tank round the pickup plate.
IIRC I used Hylomar blue "fuel resistant" when I did the original build. After googling "petrol resistant sealant" and ending up unconvinced that such a thing actually exists, I mentioned it to Angus. His prescription was pithy and to the point.
1. There is no such thing
2. Clean all the old sealant crap off
3. Abrade the mating surfaces of the tank and the plate
4. Fit a new cork gasket, dry
5. Use 2, not 1, copper washers
So I held off till the tank was down to about half full, and have just done all of the above. I stuck duct tape upside down inside the hole to catch the debris (a bit of a race against the petrol fumes slowly dissolving the tape adhesive, it all got a bit sticky) and used a powerful vac to hoover up the fragments as I went. To finally clean up the last traces of sealant before the dry assembly I found the most effective solvent was.... petrol
Then I touched up the tank with some black chassis paint.
We'll see if this works.
