#1 Changing Rear Wheel Bearings, Finding Shims ?
Posted: Mon Jul 18, 2022 3:19 pm
by rfs1957
This post started off about shims and morphed into changing bearings.
I did search around a bit before posting, and remembered with some pleasure the erudite, and generally well-mannered, exchange we had here :
viewtopic.php?f=3&t=15887&hilit=tapered+bearings
Irrespective of whether you're of the pre-load or end-float schools, they both depend on the thickness of the C.19110 series of 0.109" to 0.151" shims/spacers.
HOWEVER my usual SNGB regular is showing no availability on the sizes I was going to stock up on .............
And it's a row of three adjacent references, so there's no sign that re-stocking them is imminent.
Is there a better source for these, please ?
#2 Re: Rear Wheel Bearing Shims - who from ?
Posted: Mon Jul 18, 2022 7:43 pm
by Phil P
Hi Rory,
You might try Andy Rayner at Hutson Motor Co; Bradford, UK. I bought a couple recently from him and if you let him know what sizes you need, he may be able to help.
andy@hutsonmoco.co.uk
Yours,
#3 Re: Rear Wheel Bearing Shims - who from ?
Posted: Mon Jul 18, 2022 8:32 pm
Alan Slawson rebuilds hubs.....but cant you wait till you measure whats required then get them machined up locally. ...Steve
#4 Re: Rear Wheel Bearing Shims - who from ?
Posted: Tue Jul 19, 2022 6:44 am
by Classicboy
rfs1957 wrote: ↑Mon Jul 18, 2022 3:19 pm
What size you after?
#5 Re: Rear Wheel Bearing Shims - who from ?
Posted: Tue Jul 19, 2022 8:14 am
I have a stack of them, but am inconveniently located :-)
To be honest it wouldn't be very hard to make them...
#6 Re: Rear Wheel Bearing Shims - who from ?
Posted: Tue Jul 19, 2022 3:30 pm
by rfs1957
Thanks for offers and advice, I have made them in the past but as both hubs are in the same ballpark it doesn’t seem to be a waste of 50€ to have H J K L M in stock and feel confident In the luxury of just opening a packet to dial in the perfect adjustment - a figure which stirs strong sentiment nevertheless.
Andy at Hutsons is looking to see what he’s got, tho if anyone had a drawer full I’d be all ears and cheque book.
#7 Re: Changing Rear Wheel Bearings, Finding Shims ?
Posted: Fri Jul 22, 2022 11:34 am
by rfs1957
Some thoughts on re-fiting the bearing tracks.
There's no need to use a press to do this, and many advantages in not doing so - far less risk of the races going in off-cock, and taking a shaving off the bore.
This DRAPER tool set could have been made for working on Jags, the two rings shown were perfectly sized for the rear wheel-bearings, and I've lost count of the number of times I've used them for other jobs.
I boiled the rear hub-carrier up as seen, froze the bearing tracks in the freezer, and the temperature differential means that the tracks just literally drop in. A tap on the centre drift confirms the dead-seating ring, music to our ears. The risk to be aware of is that when you do the second side, the first side may still be loose and can move.
I use a drop of Loctite bearing-fit in contexts like these,just to be sure, but this method requires no peripheral hammering or juggling with spacers and anvils on a press that essentially gives you zero feedback.
Thought this might help/encourage others.
