S1 4.4 gear selection
phoenix
#1 S1 4.4 gear selection
Post by phoenix » Tue Jul 19, 2022 5:16 pm
Just fitting gearbox to engine . We tried the clutch by levering the release arm and the box seems to be locked. This gearbox was supposed to be OK is it possible whilst standing round the selectors at the tail could have moved . I.e .Two gears at once.
S1 4.2 RHD Bryan
#2 Re: S1 4.4 gear selection
Post by christopher storey » Tue Jul 19, 2022 5:24 pm
Highly possible. Have you put the gearlever back on yet? If so, did you try it in its various positions? in any event, take the box back off the engine , take the lever off , and get a largish screwdriver to slide the selector rods into the neutral position and see whether the first motion shaft can be moved then. If so, put the lever back on and repeat the test in each gear position
phoenix
#3 Re: S1 4.4 gear selection
Post by phoenix » Tue Jul 19, 2022 6:42 pm
Thanks . What should they look like in neutral. Which is the first motion shaft ?. We have tried putting the gear lever in and it seems like it is in neutral but will not select any gear .
S1 4.2 RHD Bryan
#4 Re: S1 4.4 gear selection
Post by mgcjag » Tue Jul 19, 2022 6:45 pm
Did you take the gearbox cover off prior to your box locking up......if you dont fit the top cover correctly the box can easily lock up.....Steve
phoenix
#5 Re: S1 4.4 gear selection
Post by phoenix » Tue Jul 19, 2022 7:05 pm
No we haven't touched any of the box .
S1 4.2 RHD Bryan
#6 Re: S1 4.4 gear selection
Post by christopher storey » Wed Jul 20, 2022 7:30 am
The first motion shaft is the input shaft in the bellhousing . There are 3 selector rods which each have a slot at the rear end.That for 3rd/top gear is on the left, that for 1st/2nd is in the middle, and that for reverse is on the right ( all looking forwards ) . Lever the shafts gently so that all the slots are in line, and neither frowards nor backwards of the central position , and that should be your neutral position when both input and output shafts should be able to rotate independently of each other. If that is achieved, put the lever on and check that all works normally in the usual gear positions
angelw
#7 Re: S1 4.4 gear selection
Post by angelw » Wed Jul 20, 2022 1:06 pm
The following pictures are the visual of Christopher's written description for the Neutral position of the Gear Selectors.
Bottom View
Top Cover
phoenix
#8 Re: S1 4.4 gear selection
Post by phoenix » Wed Jul 20, 2022 6:39 pm
Thanks very much for your help . This rebuild has been I nightmare . After fitting engine and box then firing up we could not get it to idle below 1200 . Found out low compression on 3 cylinders. The owner had the engine professionaly rebuilt 10 years ago but not turned over during intervening period. Result 2mm rust rings . When you thing your on the home run it's very demoralising .
S1 4.2 RHD Bryan
#9 Re: S1 4.4 gear selection
Post by DWW » Wed Jul 20, 2022 8:38 pm
Wow, that's a bummer :doh:
phoenix
#10 Re: S1 4.4 gear selection
Post by phoenix » Thu Jul 21, 2022 12:16 pm
All back together . Box on engine ready for fitting . Many thanks for your knowledge .
I am a classic Mini and Fiat 500 owner this is a great departure for me.
S1 4.2 RHD Bryan
#11 Re: S1 4.4 gear selection
Post by christopher storey » Thu Jul 21, 2022 3:03 pm
Glad you got a good result, and particular thanks to Bill for the detailed and annotated photographs .
phoenix
#12 Re: S1 4.4 gear selection
Post by phoenix » Thu Jul 21, 2022 4:28 pm
Yes they were very good photos really helpful. Many thanks Bill .
S1 4.2 RHD Bryan
