Winder mechanism
#21 Re: Winder mechanism
Hello Chris,
Your car being an S1.5, with the internal door lock handle proud of the door trim, the window winder mechanism can be assembled either way as shown in pictures of the two alternatives in my earlier Post. The reason for this is that the Remote Bar from Door Lock Handle to Door Lock, is on the outside of the door frame.
In fact, I believe that the original configuration for S1 and S1.5 cars is as shown in the first picture in my previous Post, the configuration that won't work with either S2 2+2 or all S3 cars. I suspect also this is where the error in the parts and workshop manuals came about.
For certain, the scroll spring should tighten as the window is wound down and therefore, the tail of the spring must be tethered at the bottom of the restraining lug.
#22 Re: Winder mechanism
Thanks for the replies Bill and Steve.angelw wrote: ↑Mon Aug 01, 2022 1:03 pmHello Chris,
I've just checked and the configuration in my car, S1.5, is the same as the "correct for S2 cars" layout as in your second photo.
So I just need to remove the spring and replace it correctly. The window winder mechanism always felt too stiff so maybe this will help.
Thanks again.
Chris
Chris
E-Type, RHD, S1.5, 2+2, 1968. Owned since 1977
#23 Re: Winder mechanism
Chris Wrote:
I suspect the way the spring got to be upside down, is that the Window Winder Mechanisms were assembled in the wrong doors to which they previously resided. As mentioned in my last Post, I believe the original assembly for S1/S1,5 cars was as per my first picture, in my first Post (incorrect for S2 2+2 and S3 Cars).
If you were to swap the Window Winder Mechanisms from your doors, Left for Right and vice versa, the scroll spring would be tethered on the correct side of the restraining lug without actually moving the spring.
Hello Chris,I've just checked and the configuration in my car, S1.5, is the same as the "correct for S2 cars" layout as in your second photo.
#24 Re: Winder mechanism
Thanks Billangelw wrote: ↑Mon Aug 01, 2022 3:27 pmChris Wrote:Hello Chris,I've just checked and the configuration in my car, S1.5, is the same as the "correct for S2 cars" layout as in your second photo.
I'll give it some thought and take the easiest route.
Chris
Chris
#25 Re: Winder mechanism
Steve, where exactly did you locate your washer to take up the free play. Here’s my pic, looks slightly different to yours.
Regards Colin.
Regards Colin.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
Topic author - Moderator
#26 Re: Winder mechanism
Hi Colin....look back at the photo i posted an it should be clear. ...i put the washer on the shaft that the handle fits to.....a different unit to yours but does the rest of the internals in the cup shaped houseing in your photo come out....Steve
#27 Re: Winder mechanism
Hi Steve, thanks. I guess they must come out but they are sprung (you can just about see the tang) so haven’t messed about with them at this point. It might be a fight to get them back in. But I think the only place I could washer is behind those internals as I need to push the whole set up forward to lose the free play.
Regards Colin
Regards Colin
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#28 Re: Winder mechanism
Uh.....yes i can see that large spring in the cup...so very different to mine..let us know how you get on and whats in there.....cheers....ps...i know someone had already opened mine.....now i look at it there could have been a similar spring......but im not going to open the good one to find out....Steve
#29 Re: Winder mechanism
Will do Steve thanks
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#30 Re: Winder mechanism
I see that SNGB have the "cup" small cog section as a repair item https://www.sngbarratt.com/English/#/UK ... 0ab88baba2
Also found this interesting artical of "cup" internals.....its almost identical to my xk150 winder and i can now see there should be a spring fitted that oncoils and acts as a "brake shoe would inside the cup" rather than just friction that i have increased by adding a washer....Steve http://www.da7c.co.uk/technical_torque_ ... anism.html
#31 Re: Winder mechanism
Thanks Steve, the large spring in the cup obviously does the same job as the missing one in yours. Think I’ll try the SNGB replacement and pull the other one apart anyway.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#32 Re: Winder mechanism
So now i know there is supposed to be a spring in the cup i had a search. .....Morris Minor mechanism looks very similar so plenty cheap on ebay to possibly scavange parts from......Steve
