SU Fuel Injection
#1 SU Fuel Injection
Post by Heuer » Tue Sep 20, 2022 1:58 pm
Came across this company who advertise fuel injection kits for SU's. https://www.classicfuelinjection.co.uk/products
Here is a car so converted.
#2 Re: SU Fuel Injection
Post by chrisfell » Tue Sep 20, 2022 2:20 pm
I’m sure SU (ie Burlen Fuel Systems) have their own which uses existing SU carbs. If memory serves, it comes in two varieties, one for standard engines, and another with chunkier injectors for tuned engines. And approx the same price.
#3 Re: SU Fuel Injection
Post by Heuer » Tue Sep 20, 2022 2:35 pm
Last mention of the Burlen SU conversion was in 2017 and no news since. Can't find it on their web site but maybe I am looking in the wrong place.
gtjoey
#4 Re: SU Fuel Injection
Post by gtjoey » Tue Sep 20, 2022 3:41 pm
Every time I like to do this, I NEVER GET A COMPLETE ANSWER.
To rich, to lean, no good at cold or breaks up at full throttle.
Anyone have a setup that works?
gtjoey1314
#5 Re: SU Fuel Injection
Post by malcolm » Tue Sep 20, 2022 4:18 pm
David, any experience of how much difference it would make to a standard 4.2 E?
neal herridge
#6 Re: SU Fuel Injection
Post by neal herridge » Tue Sep 20, 2022 4:50 pm
Tom Barclay racing is doing it, they put the injectors in the inlet manifold.
There is a you tube video of it.
They will sell you just the bits you need or do it all.
Neal.
gtjoey
#7 Re: SU Fuel Injection
Post by gtjoey » Tue Sep 20, 2022 8:43 pm
Yeah It’s the mapping that’s the killer
Ok so not much yet
Gtjoey1314
Sdinse
#8 Re: SU Fuel Injection
Post by Sdinse » Tue Sep 20, 2022 10:39 pm
Quote: Yeah It’s the mapping that’s the killer
Not really, if you use a MegaSquirt Pro for the controller. It will build an initial map that's fairly close if you input accurate data and then it will tune itself as you drive it. You just need EGO, MAP, Eng Temp and crank speed sensors to make it all work.
Worked great on my SIII V12!
1971 SIII E Type 2+2
#9 Re: SU Fuel Injection
Post by Heuer » Wed Sep 21, 2022 9:37 am
Classic Fuel Injection sell the complete kit using the MAXX ECU which seems to be the new standard over Megasquirt/Megajolt. It is pre programmed for the E-Type engine but of course you could take the car to any tuning shop with a rolling road and they can set it up for you.
Angus and I drove an EFI S1 4.2 that E-Type UK had done and we were both very impressed. Super smooth power delivery. That one used an Emerald ECU with XJ6 EFI.
