1969 vacuum check valve question
autoalain
#1 1969 vacuum check valve question
Post by autoalain » Mon Oct 03, 2022 11:23 am
Folks, below the vacuum tank (breaks) there is a check valve c27306, what does this 46.00 dollar part do?
I have a check valve from another make of car I would like to use, but because I do not have the old one
I have no idea what the process is, I guess it holds vacuum for brakes, but do not know why it needs
a check valve, thanks Mike.
MarekH
#2 Re: 1969 vacuum check valve question
Post by MarekH » Mon Oct 03, 2022 12:18 pm
It holds vacuum for the brakes. Whenever the air pressure in the manifold is lower than in the vacuum tank, the one way valve evacuates any remaining air from the tank/reservoir used to give you vacuum assist for the brakes again next time you stab the brakes. Without it, the amount of vacuum assist would depend on engine load.
A valve from any other car with power assisted brakes will do.
ianc9
Ireland
#3 Re: 1969 vacuum check valve question
Post by ianc9 » Fri Oct 14, 2022 8:47 am
I think most other cars have valves with just 2 connectors (in and out) on them. If this is the case with the one you sourced then you'll need to stick a Tee connector in the accommodate the pipes to the reservoir and the servo on the "out" side.
Ian.
1968 E Type S1.5 2+2
1953 MG TD
1974 Mercedes 450SEL
1983 BMW R70 Cafe racer
Tesla Model 3 LR - to make up for all the fuel used above!
caveman
#4 Re: 1969 vacuum check valve question
Post by caveman » Mon Oct 17, 2022 7:52 pm
Make sure you put the two pipes on the right way around. It’s the difference between a heavy brake pedal (no assist) and good pedal with servo assist. Mine was plumbed wrong for many years before I investigated further and wow what a difference.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
