#1 Hayden Electric Fan Switch IMHO
Posted: Sun Oct 16, 2022 2:56 pm
IMHO,
I have run the Hayden adjustable switch for 30 years in my DRIVER E Types….
But with this 4.2 series 1 and the small bonnet opening
Most people have 2 options
Over heat with the original set up or hot and start warping things or
Run a toggle and most guys run the fan to death.
The Hayden with a adjustment gives you the best shot for a DRIVER.
Again I was close BUT at a light after complete at temp
I would get the almost hot rattle around as the temp would climb fast at stop
So I put a test light jumper from the fan to a test bulb
I dialed the fan that once the car came to a stop and 10 seconds it would come on!
Then once moving and the heat surge about 30?seconds the light would go out!
Perfect!
Before I pulled the Denis Jenkins never on fan until HOT
But with this relay, no juice from the dash like my Halo lights
Everything runs real cool and
NO more marble rattle even at the light
These motors are so sensitive to heat
Look below
Simple stuff but it works
Ps dont trust the gauge or repro they are off 10 to20 degrees!
Gtjoey1314
My gauge is dead on 0 of the 70 a hair to the right in the 0
Perfect!
Look below
Gtjoey1314
