#1 Bell housing to 4.2 engine block technical drawing
Posted: Fri Oct 21, 2022 8:07 pm
by Rich70
Hi all.
Does anyone have a technical drawing of the bolt pattern that mates the gearbox bell housing to the 4.2 engine block?
I’m hoping someone can save me a few hours of work as I’ll have to split my setup to take the measurements.
Thank you in advance.
R
#2 Re: Bell housing to 4.2 engine block technical drawing
Posted: Sat Oct 22, 2022 8:22 am
Hi Rich....there is this drawing in the service manual but with no dimensions....i dont know of one with all tne measurements.....if your after a few dimensions then members may be able to measure for you it tbey have an engine, bell houseing thats out....Steve
#3 Re: Bell housing to 4.2 engine block technical drawing
Posted: Sat Oct 22, 2022 11:24 am
Hi Rich......i have a 4.2 auto bellhouseing on the bench i could take measurements from if it helps.....Steve
#4 Re: Bell housing to 4.2 engine block technical drawing
Posted: Sat Oct 22, 2022 1:56 pm
by Rich70
Hi Steve,
I would be most grateful if you could do that for me.
I’m not sure if you could place the housing on a scanner or photocopier? If it’s copied in sections I could then stitch the images together, in an ‘actual size’ resolution, and work from the template to build a model in CAD.
Once I have a technical drawing and assured the measurements I’ll post it here for future members.
R
#5 Re: Bell housing to 4.2 engine block technical drawing
Posted: Sat Oct 22, 2022 2:02 pm
Hi Rich....how about i do a pencil rubbing on to paper then post to you?.....pm me your name and address. ....Steve
#6 Re: Bell housing to 4.2 engine block technical drawing
Posted: Sun Oct 23, 2022 1:30 pm
by JerryL770
Rich70 wrote: ↑Sat Oct 22, 2022 1:56 pm
R
I will be very interested to get copy of your final drawing. Would be much appreciated thank you.
After that, I would need a drawing of the gearbox to bell housing face, location of the primary shaft and length of the bell housing.
#7 Re: Bell housing to 4.2 engine block technical drawing
Posted: Mon Oct 24, 2022 8:02 am
Hi Jerry.....put up a seperate post.....someone may have that info and post it....im just sending auto bell to engine info.....Steve
