Hi all
Does anyone know of the latest on Pilkington glass screens?
Also my roadster needs door glasses and I wondered if the BS kitemark versions are available ??
#1 Pilkington glass screens
#2 Re: Pilkington glass screens
Production has moved to Finland but you can still get the glass with the correct 1962 logo:
S1 OTS OSB; S1 FHC ODB
#3 Re: Pilkington glass screens
Is that windscreen AND door glass
Any idea if we can order them in the U.K.??
R
R
#4 Re: Pilkington glass screens
Yes, they will put the requested logo's on any piece of glass and can even add a heated front screen or embedded radio antenna. Order from your local Pilkington dealer using the codes in the attached .pdf download from the Forum KB:
Pilkington Classic glass catalogue: https://www.dropbox.com/s/ivyh7ob521ix6 ... s.pdf?dl=1
#5 Re: Pilkington glass screens
So, this must have changed, as few years back they only offered standard modern logo or 'vintage' looking logo.
However, the 'vintage' version was nowhere near what it looked like in the 60ies. For starters, it was painted, not sand blasted, then the text was compliant to modern standard production.
However, they had the option of selling unmarked glass for 'show and demonstration purposes' and this is the route I took.
Tadek
Tadek
Heuer wrote: ↑Sat Nov 05, 2022 4:26 pmYes, they will put the requested logo's on any piece of glass and can even add a heated front screen or embedded radio antenna. Order from your local Pilkington dealer using the codes in the attached .pdf download from the Forum KB:
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
