1970 2+2 transmission automatic question XKE
autoalain
#1 1970 2+2 transmission automatic question XKE
Post by autoalain » Fri Nov 18, 2022 11:52 am
Folks, basket case car, with ( I think) xj6 automatic transmission, there is a rubber hose coming from a
fitting on the right side of transmission, going up to the carbs (but not attached). I have gone to a transmission shop and asked what it is for, they think it might be a breather plug, but the young ones do not really know,
I have attached a pic and you will see exactly what I mean, what is it and what do I do with it. Thanks
#2 Re: 1970 2+2 transmission automatic question XKE
Post by mgcjag » Fri Nov 18, 2022 12:54 pm
You need to identify exactly what gearbox it is to tell if it is the breather.....this shows a type 35 breather so could be similar......Steve
caveman
#3 Re: 1970 2+2 transmission automatic question XKE
Post by caveman » Sat Nov 19, 2022 11:28 am
Borg Warner Type 66?
https://www.jagpartsenter.nl/product/bo ... -model-66/
There’s a video here that shows the pipe in situ at gearbox:
Here’s another showing full pipe;
Also mentions here about where the breather finishes (vents) on a BW 65 which is similar:
https://forums.jag-lovers.com/t/xj-ques ... ine/211924
1965 S1 4.2 FHC (early)
:wavegreatbritain:
